My pc keeps crashing and it give me the whea uncorrectable error and my cpu get from like 50° to 90° in 5 min ... im using a h100i to cool it ... any ideas `? I tried to install another win but it crashed while i was installing the windows...
Replace the thermal paste on the cooler and make sure it is mounted correctly and securely.
Make sure you apply the right amount of thermal paste using the correct method.
https://linustechtips.com/topic/370274-guys-i-need-help/#findComment-5013822
Replace the thermal paste on the cooler and make sue it is mounted correctly and securely.
As this dude said :D
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/370274-guys-i-need-help/#findComment-5013830
in 5 min? that`s pretty quick, please say you`ve used the thermal compound....
Im pretty sure everything is mounted correctly and even if i tried to do it again i wouldnt have paste. I heard the error has effects on the cpu ...
https://linustechtips.com/topic/370274-guys-i-need-help/#findComment-5013852
Go buy some good thermal paste from a local PC hardware store, if you don't these high temps could cause damage to your CPU over an extended period of time
https://linustechtips.com/topic/370274-guys-i-need-help/#findComment-5013877
Sorry if i am rude but did you google it before coming here?I just did and there are plenty of thing to try
https://linustechtips.com/topic/370274-guys-i-need-help/#findComment-5013882
I did and i tried everything i could with my shitty first build experience...
I read a bit of those articles and i would suggest something.Clear the hdd(re-format it in another pc if possible) and use another thermal paste and remount the cooler.If none of those will work come back and we will try some more,but as i read it might have something to do with either driver or hardware compatibility or ram problems
https://linustechtips.com/topic/370274-guys-i-need-help/#findComment-5013950
did you secured the pump correctly it could well be that you didnt screwed in all the screws and also if you touched the thermal paste and or reput it few times you may have some air boubles. and did you connect your pump to cpu fan header? make sure your pump is working
https://linustechtips.com/topic/370274-guys-i-need-help/#findComment-5013986
Follow these instructions, report any developments. Full system specs could be useful, too.
By the way, please follow your topics ;)
Ok ill try that.
Everything is secure. And the pump is working.
https://linustechtips.com/topic/370274-guys-i-need-help/#findComment-5014100
