Hi Guys,
I am a first time PC builder and I need some quick fast help.
Before I begin i just wanted to show my setup:
CPU-FX-6300
GPU-R9 270
MOBO-Gigabyte 970A-D3P
RAM-8GB (2x4GB) Kingston HyperX Fury 1866mhz
PSU-EVGA 500W 80Plus Certified
CPU Cooler-Cooler Master 212 Evo Fan
Storage- WD Blue 1TB
Case-?????????????????????????????
My question is that can you guys find any flaws in my build like something might be missing or not compatible (i.e my psu might not have enough cables) and can you guys suggest a cheap $50-$100AUD(Australian money) case that will fit everything. I was about to buy Corsair  0-3 SPEC case, but i read some forms on Tomshardware and that my cooler was not compatible with the case. ( Something that looks cool please!)
Already bought twin pack corsair 120mm fans red so can you guys recommend something that would match plz
https://linustechtips.com/topic/370135-help-me-please/
zalman z9 plus it will do, its not the best but its not the worst you get a decent amount of fans which is nice.
Im not a fan of 1866mhz ram, 1600mhz while slower normally offers a lot better bang for buck as next to no games really provide a difference. other than that it seems fine. I recommend you get a cheap case so you can put more money into the gpu. psu is fine btw.
Listen if you care.
https://linustechtips.com/topic/370135-help-me-please/#findComment-5011735
Hi about the ram, if the prices are the same-kingston HyperX 8gb(2x4GB 1866mhz)$60 and Vengence 8gb(2x4GB 1600mhz) $60 i might as well go with the kingston because it has higher speeds?
https://linustechtips.com/topic/370135-help-me-please/#findComment-5011806
Personally I would scrap the cooler, get a $50 case (whatever looks the best), and put the extra money into upgrading to an i5.  It'll work out the same $$ but be an overall better system.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/370135-help-me-please/#findComment-5011826
Yeah thats fine then, normally its more expensive but if its like then go for it.
Listen if you care.
https://linustechtips.com/topic/370135-help-me-please/#findComment-5011899
