copying data through LAN?
YOU DON'T NEED ANYTHING OTHER THAN A LAN CABLE !! Follow the steps below
Do steps 1~5 on both systems BEFORE connecting them via the LAN cable
Disconnect any internet connections on both systems. (You may use airplane mode on both of them)
1. Go to "Control Panel >> Network and Internet >> Network Connections"
2. Now right click on "Ethernet" and go to "properties"
3. Under "Networking" tab, look for "Internet Protocol v4" and double click on that to go to properties.
4. Click on "Use the following IP address" and now you have to allocate 2 different IP addresses. On first system use "192.168.1.2" and on second use "192.168.1.3". For the sub-net address just click on the blank field and it will be automatically filled up. Leave the default gateway field blank.
5. Save the settings and connect the systems via the LAN cable.
6. Go to start and type "network" and open it.
7. In the network window, click on the address bar and type "\\192.168.1.2" or "\\192.168.1.3" (this is the addresss of the other system than the one you are working right now)
8. Now you will be asked to provide the username and password for the system. Go ahead and fill in the details and press enter.
You will now be able to access the other system. Enjoy !! ![]()
