DIY? Some webstores like frozencpu.com also sell pre-modded cases.
Well frozencpu doesn't anymore, they don't sell anything anymore.
N64 HTPC: [Completed]
Main PC: i7 4770k @ 4.2 Ghz | Be Quiet! Dark Rock TF | Asus Z87 Maximus VI Formula | G Skill Ripjaws X 16GB | Zotac GTX 1070 | Samsung 850 EVO 500GB | Seagate 1TB Hybrid | Samsung 840 EVO 128GB | Corsair 1200i | Thermaltake Core P5
https://linustechtips.com/topic/368775-modded-case/#findComment-4992623
"custom" means "customized" which means you do it yourself or pay someone to make one for you, because if you just buy one from a retailer then its not custom
so maybe you should elaborate what you mean by "custom" and maybe there is a normal case that you can just buy that already has what you need
the closest thing to custom (but is not completely unique) is caselabs where you can choose the type of side panels
https://linustechtips.com/topic/368775-modded-case/#findComment-4992683
