GTX 970 Stutter Issues
Solved by Ellis_D,
I just did a quick google search on that drive and it seems like stuttering is a common problem and there is even a firmware update that claims to help the issue (if you're not running the latest firmware already). But yeah, I'd try it with the spare WD Blue. WD Blues are fortunate in that they're basic HDDs with not a lot of fancy energy saving and data cache features. I'd also make sure you're Windows power profile is set to not spin down drives when inactive (although energy-efficient drives like the Eco Green will still do this regardless) to cover your bases.
