I'm gonna be looking into new peripheals soonish, Well I am a bit of a plan ahead kind of person and I like to plan everything out so I have a find idea of what I wanna do/get. Each of these will be based of in sections
Section 1- Keyboards- Out of personal preference from my Razer BlackWidow ultimate I love the Razer Green switches. With a Actuation force of 50 Grams it's incredible. I absolutely love the "Clicking" of it but it is not needed. I've been in a stump between a few keyboards. May I add RGB/Red Backlit :). Macros are also no needed as well but it could be nice. Budget= $170 or less
I've been stuck between a few keyboards.
1. Ducky Shine II http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=152I chose this one because well. It's got a little bit of everything. It's got the Cherry MX Brown switches with a Actuation force of 45 Grams but doesn't have that "Clicky Noise" to it. It's got the Red Backlit, Only noticable logo is on the spacebar, and isn't HUGE. Also I could get the Ducky Shine 3 for like its $2 more for Cherry MX Blue switches which have a 50 Gram accuation force and is clicky. Kindda like the equivalent of the Razer Green Switches.
2. Next Up, Razer Blackwidow Chroma http://www.newegg.com/Product/Product.aspx?Item=N82E16823114051&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=I chose this basically because I know it';s something I'd like. It's got a Accuation force of 50 Grams, That Nice clicky noise. It's got macros, Its RGB but sometimes the clicky noise of it may be a bit "To Loud" at I can hear it loud and clear over my headsets.. I like the clicky noise but like I said it's sometimes to much clickyness.
Section 2- Mice-
Basically, A RGB/Red mouse would do so I found a few.
1. First off http://www.amazon.com/dp/B00MYTSDU4/?tag=pcpapi-20this one would basically be to max the Razer Chroma, It's clean, Simple, It will obviously be red in one way or another, no sometimes annoying macro buttons ect. Simple as that
2. Now http://www.amazon.com/dp/B007WTAJTE/?tag=pcpapi-20This is the mouse I have now. But it's the green one. Sometimes the 6 extra keys get annoying but I could easily just disable I am just lazy. I love the way it traps my fingers in so they don't slip off. It's glowing red and would look good witht he Ducky shine or the Razer Chroma basically I just can't choose between the two so I want your Ideas.
Section 3- Mouse Mats.
Now this is a tough one because I know nothing about them. I'd like it to be a black one, Logo or no logo doesn't really matter. I wanna hear your guys ideas on full desk mouse mats. Are they worth it? How do they feel when typing since your arms will obviously be sitting on it ect.. Does it help when the mouse isn't falling off the mousemat? Right now I have some generic 6x6 inch mouse mat and sometimes it seems to small. My local bestbuy as a 12x10 inch SteelSeries mouse mat, Are they any good? Or would I be better off finding a full desk mouse mat ? I truly do not know.
Section 4- I misewell since it is technically a "Peripheal" But Speakers.
I know nothing about speakers. Literally nothing, I just like headsets but when I am home alone nice set up speakers would be nice. I really don't want no more then like 3 speakers and they don't have to be some $300 set of speakers. Just something for gaming, A set of 5 may be nice aswell. Or a soundbar but I don;t think those are any good for gaming.
Section 5- Other
Sound Cards? LEDs? Anything else to "Spice Up" a setup pretty much. Thanks :)
EDIT
Section 6- Desk
So basically I live no where near an Ikea, The closet one would consider me leaving the country lol. Anyone know of desk that could be made into like long desk, Add-on to it later kindda deal, So have a uppercase L kindda shape so the shorter end can have stuff like a Lava lamp, I love lava lamps. and the longer end would consist of a triple monitor setup? About 8 FT Wide( Not counting the Square corner) And the shorter end about 6Ft Wide? Something easy to cable management plus the corner will have my PC angled for the window. A pretty big desk basically.
Edited by DarkBlade2117
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/366762-a-bit-of-help/
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/366762-a-bit-of-help/#findComment-4967064
Get the Ducky and the Razer Chroma.
|<eyboards
rnice (second tab is mouse pads - primarily larger)
speakers
or
The 3nchilada
Helped me no way shape or form lol.
https://linustechtips.com/topic/366762-a-bit-of-help/#findComment-4967079
Can't stand Cherry MX red. It feels like you are typing on a hologram. I don't really feel you could say "attracked" to Corsair keyboards. In my opinion they have no style, Any of there actual good keyboard use horrible Cherry MX keys ect.. Thanks for the suggestion but no thank you.
https://linustechtips.com/topic/366762-a-bit-of-help/#findComment-4967086
Section 2- Mice-
Section 5- Other
EDIT
Section 6- Desk
Yo!
Ducky shine for certain. Won't even discuss that,
Of the two mice, the Deathadder is the best of those two. If you aren't getting really hardcore into gaming (as in "scholarships available to winners of this CS;GO tournament) then an M65 RGB could also do you well.
For the mousemat a full-size Corsair or Perixx one would be best IMO.
For Speakers, please check the Audio subforum. Start a new topic there :)
You don't need a sound-card unless you're editing movies for cinemas or making professional-level music. LEDs are an opinionated thing, though I know nothing about them at all so ask around in General Discussion.
I don't know desks since mine is a 40 year old one handmade by a guy I know. I would just go to a nearby Ikea and try around what works.
https://linustechtips.com/topic/366762-a-bit-of-help/#findComment-4967387
Yo!
Thanks :) I'll probably stick with the Naga Hex unless next time I go up to Bestbuy to try out mice the DeathAdder feels better.  I'll start a forumn in Audio :D
https://linustechtips.com/topic/366762-a-bit-of-help/#findComment-4967442
