Hey guys, Recently I have had a problem with what is presumably my on board audio, during Skype calls or Razer Comms people in the call can hear my computers audio. For example if i where to watch a You Tube video the audio from that is broadcasted to everyone in the call, i have bought a new headset, tried re installing the drivers for Realtek HD audio, but still no luck! If you guys have any idea on how to fix this please let me know. I was wondering if a new sound card would be of use to me?
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/36675-on-board-audio-issues-help/
I would expect it to be due to a setting in the drivers or a wire issue. If it's a wiring issue, try and find a method of putting sound through only one side (left/right) and using the voice recorder see whether the sound plays on only one of the sides. If so, it could be a front panel audio issue, but if its on both, look for an option in the driver settings to loop or echo audio through the other.
HTTP/2 203
https://linustechtips.com/topic/36675-on-board-audio-issues-help/#findComment-470900
My Motherboard is a Gigabyte 78 LMT-S2P. I have tried both the front connectors and rear, It never used to to this and I haven't changed any settings, i think that the on board audio is broken, would a separate card do the trick?
https://linustechtips.com/topic/36675-on-board-audio-issues-help/#findComment-471190
Yeah, i have used 2 different headsets the problem is still there.
https://linustechtips.com/topic/36675-on-board-audio-issues-help/#findComment-471547
Yeah, i was looking at this one, i need something cheap as i am low on money. I was thinking this one.
http://www.dabs.com/products/asus-xonar-dgx-pci-express-5-1-channel-gaming-audio-card-821K.html?q=asus%20xonar%20dgx&src=16
https://linustechtips.com/topic/36675-on-board-audio-issues-help/#findComment-472154
Sounds good. I think it's probably the best you can get in the price range, and better than the onboard audio even at that price. I'm no expert though.
HTTP/2 203
https://linustechtips.com/topic/36675-on-board-audio-issues-help/#findComment-472205
i ALWAYS reccomend buying a cheap soundcard it makes SO MUCH diffrence trust me see my build in the signature i have a 50$ soundcard and it was a huge upgrade for me (even bigger than making the titan SLİ)
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
https://linustechtips.com/topic/36675-on-board-audio-issues-help/#findComment-472240
Okay, thanks for your help guys, ill mention if it works :)
https://linustechtips.com/topic/36675-on-board-audio-issues-help/#findComment-472787
