Have I done right?
Go to solution Solved by Applesean,
Ok so after talking with both Gigabyte and Crucial i have fix the problem, I first asked crucial if there memory was ok with my board seeing as it was not on gigabytes list and they told me it was fine and i should ask Gigabyte if there was a BIOS setting i needed to change, gigabyte told me enable XMP so I did but the pc still crashed at 1600MHz, so i then put the voltage up from 1.5v to 1.55v and that has worked now got my pc stable at 1600MHz
Thanks again everyone for help
System Build
AMD FX6300
Gigabyte 970A-UD3P
Sapphire Radeon DuelX R9 270X
2x4GB DDR3 Ballistix PC3- 12800 CL9, 1.5v
Corsair CX600 PSU
Seagate Barracuda 1 TB HDD
OS Windows 7 home (64bit)
I built this pc following a guide on YT, I'm new to pc gaming/building and didn't have a clue on how to build one, everything went fine only took about a hour and a half to put all the parts together but i had major problems when putting my OS on. The pc would either freeze or crash when trying to install the OS, it took about 9 hours of google/youtube and head banging till i got it stable,
it was a setting in the BIOS for system memory multiplier witch was on auto 8/1600mhz i put this down to 4/800mhz and the OS installed and everything has been running smooth since, the problem is i don't know if what i did was the right thing to do, i have notice when using PC wizard that my ram wasn't running in DDR3 my sticks can run DDR3 is it my mobo that cant? I have learned alot about pc's since building this ( thank you LTT) but can not get my head around this one nd google or YT don't want to help me this time either
Any help would be very much appreciated Thanks.
My PC: i5 4690k===MSI GAMING 3===980TI===8GB-Corsair-Vangence-Pro-Series===H100i-GTX===EVGA G2 750W===Samsung 850evo m.2 boot drive===Samsung 250gb evo SSD===Seagate-Barracuda-1TB-HDD===NZXT-H440
https://linustechtips.com/topic/366485-have-i-done-right/
System Build
AMD FX6300
Gigabyte 970A-UD3P
Corsair CX600 PSU
Have you put the sticks of RAM in the right slots? Put them in the one closest to the CPU, and the third one away from the CPU :)
Build: GPU: MSI GeForce GTX 780 CPU: Intel i5 4690 MoBo: AsRock Fatal1ty H97 Killer RAM: Kingston HyperX Beast 16GB PSU: Seasonic 550W 80+ Gold Case: Corsair Obsidian 500R
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4963815
This. Check your mobo manual to make sure you have the DIMMs in the proper channels. They should be able to run at their default 1600MHz.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4963827
Ok thank guys, my ram are in the right slots 1st and 3rd from cpu (same coulor), but i will still have a good read of the mobo manual and see if there is anything wrong I'll post again when i find out more
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4963889
I've read the manual and found out i had the wrong drivers, i had the (rev 1.0) when mine was (2.0) not major but i fixed it, I then tried to go back to 1600mhz but i froze with awful sound before i got to desktop, i then went down 1 to 1333mhz but crashed after 5 min of being at the desktop,( back at 800mhz now)  I'm not a major pc user and dont want anything but to play games and it dose that fine.
will getting it to 1600mhz help me in anyway?  Because if 800mhz is all i need then im fine not fixing it i mean i still got my 8gb of ram.
this is what pc wizard is telling me sorry it's just a copy and paste don@t really understand much of it
General Information :
DIMM0 : Empty
DIMM1 : Empty
DIMM2 : Empty
DIMM3 : Empty
Node0_Dimm0 (Node0_Bank.   4096 MB - DIMM
Node0_Dimm2 (Node0_Bank.  4096 MB - DIMM
Memory Controller Infor
Memory Controller : DIMM
Number of connectors : 4
Max. Module Size : 2048
Max. Memory Size : 8192
Supported Speed : 70ns,
Supported Voltages : 3.3
Error Detection Method :
Error Correction Capabil
Current/Supported Interl
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4964403
What speed does task manager say the ram is at? @Applesean
RIG:FX-6300@4.5GHz 1.4V with Hyper 212 evo with LTT NF-F12:MSI Overclockers R7 260X:4x4B Crucial Ballistix Sport:GA-970A-UD3P:1TB Seagate Brracuda & 120GB Crucial M500(OS and Programs)&Sandisk SSD PLUS(Games) In a Bitfenix Comrade with an NF-F12 as exhaust and OEM case fan as front intake
''time you enjoy wasting is not wasted time''
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4964709
 Just looked in TM and opened the RM while in there i cant find where it says speed... sorry im really bad at this
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4964745
Ok just got a program called CPU-Z
this is what it is telling me about the ram
General
Type: DDR3                Channel: Dual
Size: 8gb                     NB Frequency 2009.2
Timings
DRAM Frequency                                  401.8MHz
FSB:DRAM                                            1:2
CAS# Latency (CL)                                5.0 clocks
RAS# TO CAS# Delay  (tRDC)              5 Clocks
RAS# PERCHANGE (tRP)                     5 Clocks
Cycle time                                               12 clocks
Bank cycle time                                      19 clocks
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4965061
Maybe a bad stick of ram? Try memtest86 to find ram errors. @neebuilda @Applesean
Trying that now burning the cd, my logic was when i turned down the MHz was that the mobo supports 32 gb of ram i had 8gb so it was at 8 1600MHz i thought 8gb stick, that's why i put it down to 4 800Mhz  thinking i had 4gb sticks.... logic never wins with pc's
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4965220
yeah normally we turn down speed on gpu and cpu if not stable, also. Means you should probably rma if thats the case, if anything doesn't perform to spec, send it back. You should get 0 errors with memtest86, if you get a error take the stick out and try with one stick, run agaim.
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4965270
Thanks i hope it is a bad stick i dont like the thought of paying and not getting what i paid for... so far on 32% with no errors and 1 iteration (whatever that means)
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4965362
Yeah the test passed with 0 errors, the only thing i can think now is that i messed something up in the BIOS, but then again the only reason I started messing in the BIOS was to find the problem of my pc crashing, would it be worth putting the BIOS settings on default? or is there a chance the mobo could be bad?
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4966237
try default. Can always take put the cmos battery and wait a min put it back in for a easy reset. Im not the best with amd systems.
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4966252
Check for a BIOS update as both your Mobo and RAM support 1600Mhz.
EDIT: The RAM you have is not on the officially supported ram list
Normally this is not an issue, but if you have another PC or you can get access to another PC running DDR3 1600 Mhz RAM, I would put that in your new machine and see if It is stable at 1600Mhz
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4966389
Definitely try a reset.
Did you run memtest+ with the RAM at 1600MHz or 800MHz? That could make a big difference in the results.
If the reset to default doesn't do the trick then I would bet pretty heavily on the RAM being the culprit here. I think @TDP_Equinox has a solid idea with trying another different set if you can.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4966542
I don't think the BIOS default was a good idea. It has taken me this long to get my pc up again, I kept on crashing at start up ( same point every time) and no system repair or restore was working, not even the one on my windows 7 dvd, I thought it was because the system crashed when ram was reset to 1600MHz messing up the start up  but it was sata chip thing being on AHCI when i needed native IDE, anyway i think you guys are right about me needing diferent ram, I will buy one from that list  but this will have to wait to end of month before i buy it I will leave this topic open till then.... also i think i ran memtest86 at my stable 800MHz so i will try 1600MHz tomorrow as it's 3am now and that thing took like a hour
I mainly built this for the witcher 3 low to mid settings i know but i have been playing the 360 for the last 7/8 years so all good for me, and there not 1 game on steam that i cant handle neverwinter i was getting between 60 and 40 fps, planetside 2 ran fine as well, so what problems can this 800MHz cause in games?
I'm rambling now witch i read not to do so thank you all very much for your time and help it is very much appreciated
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4967629
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4987159
I'd go back to crucial because you shouldn't have to overvolt your RAM just to get it to run at the advertised speeds.
https://linustechtips.com/topic/366485-have-i-done-right/#findComment-4989685
