GPU Thermal Compound
I removed the cooler/fans shroud thing from my G1 GAMING GTX 980. I was wondering if it is alright to leave the thermal compound on until I can get to the store and buy some isopropyl alcohol. (At least a day's time) Also, just in case you haven't taken the cooler off of your video card before, unplugging the fan connectors is the single hardest thing in the history of the world. (without breaking them obviously)
Thanks guys!
wait why? was the card having issues?
if that a new card you realise removing the cooler voids your warranty right? (EDIT: I might be wrong about gigabyte card actually if so ignore this part)
Anyway, if you are not using the card, its fine to leave the paste on - but do not put it back together and use it with old paste in that state
