Why a full tower? Is the optical drive really necessary?
Why Win7 instead of Win8.1?
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4957591
I'm trying to build a 1440p/4k gaming rig, and I need a slight price cut on what I have already. If there are any cheaper alternatives to any of my components that won't affect the performance, please let me know
My build:http://uk.pcpartpicker.com/p/VrR8kL
whats it gonna be for?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4957601
Everything is quite conservative with exceptions to the case and ram. 1600Mhz ram is no less better than 1866mhz for gaming.
What games do you play? A single 970 isn't exactly the optimal card for 4K.
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4957604
Im not really looking for 4k gaming, it's just that 4k monitors are almost the same price as 1440p monitors
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4957618
Similarly priced 4K displays tend to be bad 4K displays.
Something like this would be better: http://uk.pcpartpicker.com/p/PqgxmG
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4957710
Just get Windows off reddit.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£179.00 @ Amazon UK)
CPU Cooler: be quiet! Shadow Rock Slim 113.8 CFM Rifle Bearing CPU Cooler  (£30.98 @ Novatech)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  (£89.99 @ Novatech)
Memory: Patriot Signature 8GB (1 x 8GB) DDR3-1600 Memory  (£40.00 @ CCL Computers)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  (£41.87 @ Scan.co.uk)
Storage: Western Digital RE3 1TB 3.5" 7200RPM Internal Hard Drive  (£34.25 @ Amazon UK)
Video Card: Sapphire Radeon R9 290X 8GB Vapor-X Video Card  (£369.31 @ More Computers)
Case: Corsair 300R ATX Mid Tower Case  (£59.98 @ Amazon UK)
Power Supply: SeaSonic M12II 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£79.44 @ Scan.co.uk)
Optical Drive: Samsung SH-118CB/BEBE DVD/CD Drive  (£9.78 @ Ebuyer)
Monitor: AOC U2868PQU 60Hz 28.0" Monitor  (£325.54 @ Scan.co.uk)
Total: £1260.14
Generated by PCPartPicker 2015-05-13 22:07 BST+0100
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4957712
Any monitor with a lower response time?
The response time spec is bull and should generally be ignored unless it comes from a in-depth benchmark or review. Most modern displays including that which I recommended have low enough response times that it shouldn't be something to worry about.
Refer to: http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4957798
Total: £1260.14
Apparently the GTX 970 performs slightly better than the 290x
Is there also a problem with the PSU?
Edited by owenrees1
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4957808
Not at higher res, the R9 290X smokes the 970 at 1440P and higher and you got to consider that the R9 290X card has 8GB VRAM vs GTX 970 3.5GB/4GB Vram.
https://linustechtips.com/topic/366007-need-pc-build-help/#findComment-4961220
