Bitrate. For 1080p60 you need a ton of it. Shadowplay uses 50mbit. I recommend you get dxtory and use it together with obs, the nicest setup.
https://linustechtips.com/topic/364793-obs-record-settings/#findComment-4941828
So I have an i5 4690k at 4ghz and when I switched to obs from fraps for the file size reasons and some other unimportant ones. But when I recorded this video this was my first video and I want to know if there was any way I could make it look better.
Definitely bitrate-limited.  You're streaming at 1080p@60fps, and the max bitrate that Twitch or similar platforms will accept is 3500kbps up.  That is not enough for high quality recordings/streams.  At that bitrate you are better off going 1080p@30fps or 720p@60fps.  I personally use 1080p@30fps for WoW because I have done extensive testing and noticed that at these settings, the video was clearer in all aspects compared with 720p@60fps watched on fullscreen on a 1080p monitor.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/364793-obs-record-settings/#findComment-4941855
Dxtory is extremely expensive, I wish I could though.
30$ is not extremely expensive, but I get your point.
https://linustechtips.com/topic/364793-obs-record-settings/#findComment-4941859
Heeeeeeey, click the link in my signature.
QuickSync recording at 3500kbps is literally the worst quality of any recording option in OBS.
https://linustechtips.com/topic/364793-obs-record-settings/#findComment-4941893
No shit, that's why I don't recommend it.
But the link in your signature is a guide on how to setup QuickSync recording in OBS.... I don't get your point.
https://linustechtips.com/topic/364793-obs-record-settings/#findComment-4941991
can you show me your settings or your exact bit rate and take note I am using it to record not for streaming, my internet cannnot handle that.
https://linustechtips.com/topic/364793-obs-record-settings/#findComment-4942225
if it's for local recording, just whack the bitrate up and go with it :D  Although with GameDVR for AMD, you can record with that for much less resources.  Takes at most 1-3% GPU performance for vastly improved video recording.  Haven't used GameDVR since last year when I upgraded to the 970 (ShadowPlay is awesome btw), but back then it was a little unstable at recording.
This video however is a sample of 1080p@30fps at 3500kbps
Compared to ShadowPlay at 30Mbps 1080p@60fps
I expect GameDVR video quality to be similar to the 2nd video.
https://linustechtips.com/topic/364793-obs-record-settings/#findComment-4942276
