so i just finished my first completely independent build (yay!) with the following specs
i7 4790 (stock cooler)
gigabyte z97n-wifi (i know, locked processor on a z97 motherboard, but this was the only lga 1150 mini itx motherboard available)
8 gb *1 corsair value select ddr3
gtx 960 (non gaming edition from msi)
2*256 gb adata ssd (dont know the exact model number)
corsair cx600m
all of this plus an Optical drive in a bitfenix prodigy m case
i boot it into the bios normally (no problems till here) and going to the "classic mode" it shows the cpu temp at 65 C rising steadily and at the point when it hits 80 C i shut it down to prevent any damage. i dont know if it will rise further. this is when the ambient temperature is below 25 C. on removing the side panel the cpu temp holds steady at 45 C.
i have removed one of the included two bitfenix fans as the motherboard only has one fan header apart from cpu fan. the remaining bottom mounted fan is configured as intake. i am using stock thermal compound on the cpu cooler and have made sure that the case fan and the cpu fan are both running.
could it be the poor cable management restricting airflow, or maybe the bad thermal compound? i need help.
PS: i havent yet installed an operating system out of fear of ruining the cpu.
https://linustechtips.com/topic/364360-abnormally-high-cpu-temps/
corsair cx600m
My first 4790k went to 90c on the stock cooler! I rma d it and got a cooler also. Haven't had any issues since. With the side panel off it shouldn't be that much of a difference, unless your cable management is like a hoarders house. Or it could be that the cpu cooler isn't entirely seated to the cpu completely. The cooler should have just popped into the holes you only turn the pin deals to take the cooler off and there's the possibility it's a bad cpu...
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
did you overclock it? the temp difference with the side panels off is what convinced me that it isnt a bad cpu. the cooler is properly seated in the holes. the pins have tiny little heads popping out the back. should i remove the cooler and reinstall it?
Mine was stock speeds. You can try to remove and reinstall the cooler, but if it doesn't lower I'd recommend rma ing it or getting an aftermarket cooler. If you get the aftermarket cooler the cpu could still be bad. So it's up to you to decide
Main Rig
Plex Server WIP
One fan for the whole case is awful...
Main Rig
Plex Server WIP
Don't hate on one case fan...
I run my current build with only one exhaust fan, and everything runs below 60C even with the OC CPU on stock cooler :P
plus my room alone is about 75F
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
80C will not damage the CPU. It can 100C before shutting itself off.
