The other day i was Getting off the Thermal paste off all my Old CPU (AMD A10 6800K) i had no isopropyl alcohol so i just cracked open a bottle of Jim Beam, put some on paper towel and it came right off and cleaned well
Would you reccoment i use isopropyl alcohol to clean it later on before i use the CPU  n my HTPC i'm building
"Life's too Short, Use Express Install" Express install subject to spying
                                        -Microsoft 2015
https://linustechtips.com/topic/364198-ghetto-thermal-paste-removal/
I would recommend it but it isn't that bad if you poor some liquor on your CPU.
24 fps for that "cinematic" feel
After a couple weeks of behavioral sciences at my school I can easily conclude my parents need to grow up.
Na mate it's just like isopropyl. It just evaporates off leaving no trace, as long as it's a high alcohol content (40-60 %)
I just cleaned my i5 with some Johnny Walker Green Label from last night :D
i dipped my cpu in water, shuold be clean right?
Face fucking palm, did you get the pins wet?
I've used Barbasol aftershave before!  I just dipped a Q-tip into the bottle, it worked like a charm. :lol:
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
i stuck thhe pins into my skin and put a cpu cooler in to my arm, it still runs
Make sure you wrap it around your dick. If it wont bend heat it up and stab the pins into your dick.
I lick it off, you will be fine.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Next time I might use some dirt and leaves, my friend says it works like a charm
                                        -Microsoft 2015
