I have a Lenovo G505s for light browsing and light gaming and my idle temps are at 100 degrees C.  The maximum it reached was 119 degrees C. Is that normal?
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/363153-cpu-temps-100c/
No, its high. Could be dust in the vents or bad thermal paste.
Are the fans running high?
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921418
I dont know what CPU is in that but i'd assume that it would turn itself off once it reached about 110 degrees, if it is going to 119 then there is very possible permanent damage being done
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921425
That's weird. I don't know if the sensors are reading the right temperatures because my CPU package temp is 98 average right now.
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921429
If the laptop feels really hot, its dust. If its cool then its a bad sensor. (I've got 'bad' thermal paste in my laptop and its temps stay well under 80oC).
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921430
It's and AMD A10-5750M APU with a Radeon 8650G.
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921441
It's cool and it says 90, then when i run the benchmark the exhaust gets really really really hot and it gets to around 105. I have no clue why.
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921451
A bad sensor would still cause the PC to blue screen because it thinks it has reached that temp and shuts down to prevent damage from occurring.  If it isn't doing that I am not sure why.
What software are you using to read temperature?
cpu HWmonitor
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921455
probably a bad sensor mate, you'd know about it if the lappy was 120C
That's odd. The GPU temps stay at 35.
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921457
Looks like it would have the A10-5750M
You are right :o
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921461
probably not a sensor fault then, bad thermal paste application at factory or something
Ok. I've had my laptop for a year and its doing perfectly fine. I don't know why that's happening. The fan is dead silent until i run a benchmark.
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921466
If you are using HWmonitor make sure you are looking at the core temps, ex. Core #0, Core #1, Core #2, and Core #3.  Those are the temps that you want to be watching.
I don't see any. The temps i see is for "Package" and the only thing that's there for Core #0 ,1 , 2, 3 is the clock speed.
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921478
Try downloading core temp or real temp.  Those will specifically display your core temps, which is important.  CPU temp in HWMonitor isn't really the proper value.  I'm not sure where that value comes from, but I know the two are not the same.
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921491
Try speccy for monitoring temps, or realtemp.
Even if the thermal paste was dried or barely there the temps wouldn't get that high.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4921625
i doubt the laptop would be 37C under full load
is that even possible with anything resembling portable?
Everything you need to know about AMD cpus in one simple post.  Christian Member
Wii u, ps3(2 usb fat),ps4
Iphone 6 64gb and surface RT
Hp DL380 G5 with one E5345 and bunch of hot swappable hdds in raid 5 from when i got it. intend to run xen server on it
Apple Power Macintosh G5 2.0 DP (PCI-X) with notebook hdd i had lying around 4GB of ram
TOSHIBA Satellite P850 with Core i7-3610QM,8gb of ram,default 750hdd has dual screens via a external display as main and laptop display as second running windows 10
MacBookPro11,3:I7-4870HQ, 512gb ssd,16gb of memory
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4922069
It is a sensor fault otherwise how can the laptop be felt cool when then reported temps are 90c on CPU ?
| CPU: Intel Core i5 8400 | Motherboard: MSI Z370 PC Pro | CPU Cooler: CM Hyper 212 PLUS | GPU: Zotac GeForce GTX 1070 AMP! Edition | RAM: G.Skill Aegis 16GB DDR4 2400 MHz | PSU: Corsair VS650 | SSD: SanDisk SSD Plus 120GB | HDD: Seagate Barracuda 2TB | Monitor: Dell S2240L | OS: Windows 10 Pro x64 |
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4922081
Are you sure your not reading Farinhight
Nope, 90 degrees Celsius.
https://linustechtips.com/topic/363153-cpu-temps-100c/#findComment-4924424
