ya just get some drive copy tool
i am sure theres lots of em
or nm not sure if it will work with a different system
the system might make u re-register.
but if u got cd key just use phone in option and say u have 1 computer, it will let u authenticate again lol last time i checked anyway
So i was wondering, is there some way to transfer windows from a computer that has windows 8 to an SSD/ hard drive? I currently have windows 8 on my laptop and i don't want to have to buy windows 8 when i build my desktop next month.
get the key off the laptop with magic jelly bean
you won't be able to use the key on the laptop anymore tho
you will then have to download windows 8 iso file and install to the desktop with the laptop key...
this ..should/might work
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
I found a spot on the Microsoft website where you can download the OS  for free. it downloads this program that allows you to transfer it to a flash drive or save it to a ISO file. I believe you need a CD key to access the OS though and these can be purchased online.
http://windows.microsoft.com/en-us/windows-8/create-reset-refresh-media
