What monitor should i get for a GTX 970?
NewGUYgamer
I tried plugging in a 8 year old monitor and it didnt fit lol what monitor specs should i look  for?
That totally depends on what you want.
Basically any cheap monitor from Samsung, Acer, BenQ, Asus, ... will do.
I would definitly recommend an IPS display for better colours and viewing angles.
Response time isn't that important. As long as it is under 10ms you're definitly fine.
You might want to check out higher refresh rates that can range from 60 to 144Hz. They can be wonderfull for gaming.
As above stated, Also a 970 is almost perfect for 1080p, and will work well with 1440p gaming, but will suffer with some games if you try pushing 4k through it.
I believe this could be a noticeable upgrade for you.
No budget mentioned.
Get 1080p 144Hz Gsync monitor (if they make Gsync for 1080p).
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
