Water Cooling Suggestion?
Go to solution Solved by Abydiot,
well I'm gonna start to take these suggestions.
Ty all!
So, I'm a beginner at pc tech.
I need an Water (or air) cooler for my cpu. any suggestion?
My spec:
-Intel i5 4690k
-Gigabyte Nvidia GTX 750ti Windforce Edition
-Gigabyte G1. Sniper B6
I know my spec are bottleneck but I need the suggestion for the cooler.
Spending that much money on a water cooler, would probably not be in your best interest, as it could be better spend elsewhere...
A decent air cooler should do you just fine. Some suggestions include the hyper 212 (real good value but not the best performance), some of the non massive ones from noctua are quite good. I believe be quiet also makes some damn fine looking coolers that perform well as well...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/360836-water-cooling-suggestion/#findComment-4891765
I am not sure what exactly you want.
But aircooler seems to be the right thing you want to me judging by your components
4690K and 750ti are cool enough.  The $ to build a custom loop can be spent to upgrade your components largely.
A closed/semi-closed loop would be good but I really don't see any reason to choose them over a high-end tower heatsink because ur gpu won't give you heat wave in the case.
To be specific, you can get Be quiet!, Noctua...
or as cheap as those Coolermaster/Enermax/Thermalright, really good $/performance.
https://linustechtips.com/topic/360836-water-cooling-suggestion/#findComment-4891771
My spec:
-Intel i5 4690k
http://linustechtips.com/main/topic/360833-air-cooling-suggestion/#entry4891979
...please don double post :D greatly apprecieated ;)
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/360836-water-cooling-suggestion/#findComment-4892208
