Hey guys I am thinking about something to upgrade, and I am not sure whether to get an SSD or a new graphics card. The card will be for folding and playing games obviously. The reason I am looking for an SSD is i think that is the bottle neck on my computer (not in terms of games), when booting and opening programs in general. What do you guys think? Budget is around 200 bucks I would say.
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
https://linustechtips.com/topic/360412-best-thing-to-upgrade/
what is your gpu
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886646
what is your gpu
Its in my signature.
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886652
While an SSD will improve general system performance you will have little else to show for the upgrade aside from booting faster, I would upgrade the GPU as it would make more of a difference.
"The of and to a in is I that it for you was with on as have but be they"
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886661
I would save some more and buy a new CPU and MOBO, your GPU is still ok.
Lol  i just got cpu and mobo because it was better than what I had.
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886685
A better GPU wouldn't be bad. Something like a R9 280 would be a nice little upgrade.
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886698
For 200$ you could probably get a better GPU and an SSD, R9 270X Maybe?
i7 8086k @ 5.3Ghz / 32GB DDR4 Trident Z RGB @ 3733Mhz / Aorus GTX 1080 11Gbps / PG348Q
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886701
An i3 would be better than this cpu though...
How much did you spend on that?
I got the cpu for 39.99 so it was a steal
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886703
I would get an SSD.  Youll notice a big difference.  your gpu is good
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886713
I just am not sure if that CPU is quick enough to not bottle neck something like a r9 280...  Even if it does bottleneck it, it would be a lot better gaming performance than a 7770.
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886726
Yeah I could possibly try to overclock the cpu a little more to see how fast I could get it to go.
https://linustechtips.com/topic/360412-best-thing-to-upgrade/#findComment-4886959
