so i just built my new system but when i have only the cpu, one ram model and just the SSD the pc stops on thew asus splash screen.
when i plug my gtx 970 in, it goes past the splash screen but then just goes to black, anyone help please.
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/359816-z97-a-issue/
someone?
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4879393
post code read out?
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4879396
post code read out?
there isn't a read out as this motherboard doesn't have a read out :L.
i've gotten it once to show me the next stage where it is detecting the devices then just goes to black again.
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4879451
i;ve noticed everytime i press delete it makes a lot of bleep sounds as well.
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4879477
Can you enter BIOS?
nope, when i try to mash the del button it goes to black as well.
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4879480
I have a Z97 - AR and they're the same minus a couple ports. They are a little weird when it comes to hardware changes. Take out the GPU, put the ram in the correct slot and then reset the bios by removing the battery, unplugging the power supply, wait 20 seconds plug it back in, insert the battery and it should boot. Once it does, put the gpu in, it will probably do a weird boot cycle then turn on, thats atleast what mine did.
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4879491
trying that now
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4879600
Specs please?
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4879601
what lights are turned on?
On the motherboard the z97-a and z97-ar have led lights on the MB that you can look up in the Manuel for trouble codes
green and red led lights
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4880018
Remove the SSD and see if you can load the BIOS.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/359816-z97-a-issue/#findComment-4880743
