USB as Installation "disk/disc"
were you talking about making the thumbdrive bootable?
use Rufus
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
yea rufus should work
personally I use wintobootic
http://www.wintobootic.in/
all you should have to do is download the iso or make it from the dvd..and load it into rufus or wintoboot..and pick the usb drive and push start
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
use Rufus
like the program or the iso image thing, when you would put in a disc/disk and the installation program would pop up and begin, and be able to do the same for a boot up to be able to select the usb as if it were a disk/disc to being installation
