I have now 660 sli and a g3258. What is the best cpu for this system. At this point a 970 is not something I want and the 660s are just fine. Is a G3258 ok or do I need an i5 4690k? I like to overclock and have the G3258 at 4.5
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/357106-best-cpu-for-sli/
I would get a better CPU, maybe an i5 4460 if you don't want to spend much. The G3258 will hold you back in games.
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846308
Second computer, or is your signature a lie? ;)
I'd go for something like an I3 at least. If you can find a good deal. Or a lower level I5 and just forego the overclocking.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846309
By how much? I have a 4770k in my current build I would be interested to swap and test fps.
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846316
Nope its a second. I am using it as a pc for a tv. Instead of a ps4 #pcmasterrace
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846324
Or dual G3258s Get up to i5 perfomance and just have a cool and pointless rig. Idk if its possible i didn't think so. only for xeons but that would be amazing.
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846359
So don't you think i3 will bottleneck 2 660s? :D My opinion that he should save money and go for i5 for a good performance though :P
CPU:Intel® Core™ i7-3930K Processor Ram:Kingmax 2GB DDR3/1333Mhz VGA:Asus R9 290 Direct CU II HDD:Seagate Barracuda 250GB Mainboard:Asus Sabertooth X79 TUF
PSU:FSP SAGA 650w
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846369
well.... far cry 4 it would hold you back by 100%. it won't run on anything less than a quad core. this is the tail end of dual core gaming right here. other games would see significant bottlenecks. hell i'm not even sure if the pentium can properly feed an sli set up. try running a recent AAA game with msi afterburner running. monitor the GPU load for both gpus. that'll tell you what you can expect. turn vsync off for this. if the cpu is close to 100% usage and the gpus aren't well you have a bottleneck.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846415
This isn't a matter of SLI or not. 2 cores for modern games just don't cut it. If you are on a tight budget, get a non-OC i5
Yeah, maybe a 4460 might be a good call if you're not OCing....
FYI, you won't be able to go 3-way SLI (Not that I'd recommend it anyway....) unless you get a CPU with more than 16 PCIe lanes, which will be LGA 2011 for intel CPUs
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846421
and guys my planw as to get to an i5 during the summer or black friday. the g3258 was 50$ and a fun test. The 660s are fine for wgat i play and if the g3258 is good i wont upgrade but the i5 4690k or (open to suggestions of the lga 1150) something around 350 maybe.
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846537
Oh noooooo you're one of those
Definitely not possible...and the costs would be huge! Once you factor in the expensive mobo and such.
Haha, perhaps a bit, but at least he'd be able to run games that require more than two cores ;)
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846588
Yea I am one of  those. I have 2 Ps3. I dont use them but I have them. They each power a racing chair.
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846604
And guys.  I have  660s and a G3258. I dont want to run out and get a new cpu just yet. If there is a big sale then fine. But I am out of cash right now. Micro center has the 4690k for 200 but I have no money now.
https://linustechtips.com/topic/357106-best-cpu-for-sli/#findComment-4846619
