MX Blue? good "tap tap tap"? Cougar 700K?
iM8Pizza
I still haven't own (yet) a mechanical keyboard. Still on membrane, i wanted to go with the Blue (BECAUSE IT'S SOUNDS SO GOOOOOOOOD), and anyway.... is double tapping with it easy? I mean, i would use it for gaming as well, and it would need a lot. A LOT. Of double tap. Is it easy to double tap? I don't know much about Cherry MX switches. And is Cougar 700K good? Or perhaps any other alternative (with multimedia keys and programmable buttons, cougar is fully programmable)? Or should I go with the Ducky Shine 4?
That's all. Please answer :D
Double tapping is easy
I play GTA just fine where I have to keep tapping to turn
Intel Core i7 9700k - EVGA FTW GTX 970
Hopefully this article can kind of help since I am rushed to put in an answer to try and help. http://www.keyboardco.com/blog/index.php/2012/12/an-introduction-to-cherry-mx-mechanical-switches/
And what is your budget for the keyboard and what backlighting do you want if any?
Read the link in my sig for all info on switches.
The Ducky Shine 4 is in my top 3 keyboards, so yeah, safe choice.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
Below $200.backlighting... well, Magenta or Blue, and Multimedia Keys, and Cherry MX Blue
What sig? :| could you just give me the link instead? My net is really slow right now :|
It's here: http://linustechtips.com/main/topic/255051-what-key-switch-should-i-get-look-here/
