[Solved] Sexy adapter for PSU jump starting
reyncor
Does anyone know of a cheap female adapter that will jump start a PSU for pump / LED strip testing?
Shorting the green pin seems unprofessional, dangerous and unattractive.
Any Ideas?
I looked on ebay, nothing useful popped up... nothing on monoprice either.
If you don't know what I'm talking about: http://www.instructables.com/id/How-to-power-up-an-ATX-Power-Supply-without-a-PC/
SOLUTION:
The Antminer ATX PSU Jump Starter, could be better, but given what it is... it's sexy enough... sure beats a paper clip.
http://www.amazon.com/AntMiner-Supply-Jumper-Switch-Bitcoin/dp/B00OJNBWKG/ref=pd_cp_e_3?ie=UTF8&refRID=1YQRWVY1QTHCH0EN36RK
Updated SOLUTION:
I think we can agree this is sleeker, safer, and sexier... I mean look at that race car inspired power button, I'm not alone on this am I?
http://www.performance-pcs.com/jump-start-eps-atx-24-pin-power-supply-jumper-on-off-switch-red-light.html
Most PC stores will sell a variant of this.
Generally found under PSU accessories or water cooling accessories.
Edit: Not sure where you live; but here are an amazon and ebay link to similar products
http://www.amazon.com/24-Pin-STARTER-BRIDGE-WITHOUT-MOTHERBOARD/dp/B00K38IKRY
http://www.ebay.com.au/itm/ATX-Power-Supply-JUMPER-24-PIN-NO-MORE-PAPERCLIPS-/261860281022?pt=LH_DefaultDomain_0&hash=item3cf816cabe
[spoiler=REDWING]  REDWING   | Custom Hard Line Water Cooling Loop   |   Intel i7-4790K @ 4.7Ghz   |   Asus Maximus VII Ranger   |   Corsair Dominator Platinum DDR3-2400 2x8GB   |   2 x Gigabyte GTX970 G1 Gaming (SLI)   |   Corsair AX860i   |   Samsung 850 Pro 512GB   |   Corsair Obsidian 750D   |   Corsair K95 RGB & M65 RGB   |   Samsung SyncMaster S27B370
Project Redwing Build Log
[spoiler=ZedNAS] 'ZedNAS' Home NAS Build   |   Intel Xeon E3 1231 v3   |   ASRock Rack E3C224D4I   |   Kingston KVR16E11/8I 2x8GB   |   Corsair HX750   |   6 x HGST Deskstar NAS 4TB 7200RPM HDD   |   Fractal Design Node 304 mITX Black   |   FreeNAS w/ PleX   |   ZFS Raid-Z2 (16TB Effective)   |
They are called PSU Bridges, found some italian ones... Not much better than a paper clip tbh. I was hoping for something that isn't so incredibly easy to catch on to something and break.
http://www.ebay.com/itm/24-pin-ATX-Starter-Jumper-Jump-Start-Bridge-PSU-Mining-/261858916334?pt=LH_DefaultDomain_101&hash=item3cf801f7ee#shpCntId
you obviously dont know how to use google very well...
Just use a paper clip, sure it looks unprofessional, but if you just make sure to plug into the right pins, it's not dangerous.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
Are all those pins 5 volt? I'm still concerned as the antminer one has exposed contacts.
... Just after buying the ant one on Ebay... I kept hunting everywhere... found this beauty. Hope the eBay seller will accept my cancellation.
Yep i just assumed you wanted a proper one instead of a paperclip. They serve the same purpose as a paperclip, are functional, safe, and always get the job done.
My mistake, You should have said you wanted something with bling. >_<
There is nothing dangerous about the paper clip.
