Hey.
I am planning to build my own PC, and i was wondering if this build is okey?
http://pcpartpicker.com/p/C6NdYJ
The things i wonder about is:
-Should i use the R5 or should i use a H440?
-Is the PSU okey?
-Is there another liquid cooler on the marked for around the same price that is either: Better, quieter, cheaper or has a better buildquality
-And if there's something else i need to change.
Thank you in advance for all your replies!
https://linustechtips.com/topic/356184-first-gaming-pc-build/
What're you going to be using it for, at which resolution and what is your budget? Looks unbalanced if it's for gaming.
My budget is around 1000 to 1500 dollars, and i dont want to change neither the GPU or the CPU.
Goin to use it for gaming and for multitasking.
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835047
i7 for a start, paired with a crappy AiO, PSU is way overkill even for a future SLI setup which he can't do anyway.....
I am planning for a SLI upgrade in the future, and i have a couple of HDD's lying around which i am planning to put in. + a DVD reader/writer
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835075
also planning to put in some extra noctua fans, or maybe replace the ones that is already there.
I want my pc to be pretty quiet under normal/low load
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835094
It's a good build.  The PSU is good, but more than you need unless you want to SLI later.
The cooler is the only thing I would change.  If you want to overclock, get a NZXT X61 (it's the quietest and has very good cooling).
As for the choice between the R5 and H440, it's all personal preference.  They are both excellent and very comparable.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835101
OHHOHHHH * crying out of pain and laughter *
my friend , get ready for a heap shit of storm .
tips :
1. check if youre putting the mobo right in the case properly and check if youre putting the support pins right , other wise you will bend the mobo.
2. check if youre putting the cpu in the right way , and do not take out that black thing ontop of the chipset , Otherwise you will bend the pins inside of the chipset.
3. put the psu FIST , becasue it will be easier to you to cable manage .
4. Have a good work envoirament FOR PEAK SAKE .
basically , dont do the mistakes that i have inlisted .
trust me youre going to need it .
(⌐■_■)
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835103
thanks for your reply altough i think the x61 is too expensive, maybe a Water cooler thats inbetween those two, aroung 100 bucks maybe
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835118
tips :
i have build several Computers before just not for myself, and i wasn't the one picking the parts...
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835128
Define multitasking. Anyways, if you insist:
The case fans are for the CPU cooler by the way. If you're wondering why I chose the PSU, it's because it's a bloody good product.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($326.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.88 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($129.99 @ Amazon)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($339.99 @ SuperBiiz)
Case Fan: be quiet! Pure Wings 2 61.2 CFM 140mm  Fan  ($9.99 @ NCIX US)
Total: $1345.28
Generated by PCPartPicker 2015-04-27 15:21 EDT-0400
EDIT: Remove the HDD at will.
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835130
Hey.
-Is the PSU okey?
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($129.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($130.98 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0 Video Card  ($334.98 @ NCIX US)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Total: $1302.80
Generated by PCPartPicker 2015-04-27 15:22 EDT-0400
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835136
Total: $1302.80
Ignore my build, this is better
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835167
The X41 is a good option, it's a 140mm rad, a little thicker than normal, and i think it has the same variable speed pump as the x61, so its quiet.
PC Build
Desk Build
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835182
Total: $1302.80
Total: $1345.28
Thanks for the replys.
I was talking to a guy who works at a "computer store/ custom pc build company" and he said that i should go with minimum 750w on my PSU.
And i think i would be going with a corsair h80 or a h100 because the guy who was working with building and repairing computers said that thats the Cooler that has the best build quality and had been in to repair the fewest times
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835197
He doesn't know fucking shit then. 2 way SLI 970s run perfectly on a good 600W PSU and Corsair AiOs (although very sexy) aren't the best for the money, and the NH-D15 beats them both in every single benchmark I've ever seen.
EDIT: Just realised, "been in to repair the fewest times"?
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835226
Had the fewest complaints then.
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835248
And i used a PSU wattage calculator that was recommended by someone on the forum and it said a minimum of 750 watts, altough i did overkill it a little
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835271
You can go with 750W if you like for that extra headroom, but I'm just saying that 600W will suffice perfectly
https://linustechtips.com/topic/356184-first-gaming-pc-build/#findComment-4835295
