Hey guys...
I was too lazy to get water and i realised "Oh i could just use the condensate from my compressed air can to clean the window!!"
Then i proceed to hold my can upside down and spray. Little did i know it would leave sctatches on my pc window... (it is a corsair spec 03)
Is there anyway to remove the scratches? I think the scratches are not found on the surface but in between because i cant feel the scratches indentation when i move my finger over it!
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/355038-side-panel-scratches/
nope
new side panel
https://linustechtips.com/topic/355038-side-panel-scratches/#findComment-4822310
nope
new side panel
Noooooo D:
https://linustechtips.com/topic/355038-side-panel-scratches/#findComment-4822484
Deffinatley agree here being that acrylic/plexi is brittle the temp change will do this
So im screwed?
https://linustechtips.com/topic/355038-side-panel-scratches/#findComment-4822488
They're probably microfractures from the sudden temperature changes.
Sounds like i ccant fixt it...
https://linustechtips.com/topic/355038-side-panel-scratches/#findComment-4822494
Probably not. Scratches in any surface are difficult to remove (glass, paint, plastic, etc) simply because of what scratches are.
Of course, it's just cosmetic.
Aw :( Thanks for the help anyways! :)
https://linustechtips.com/topic/355038-side-panel-scratches/#findComment-4822611
