Problems with ASUS R9290-DC2OC
Go to solution Solved by Faceman,
Did you uninstall all Nvidia drivers before installing AMD drivers?
Might need to uninstall everything and reinstall just the AMD drivers.
If that doesn't work, fresh Windows reinstall.
So I got a new GPU on Thursday (R9290) from ASUS got it installed with no problems. Installed drivers, no problems. Start up Arma 3, no problems. This was all on Thursday night by the way. Got home on Friday night and get on computer to play CSGO, this is where the problems start. CSGO doesnt work, it starts then disappears its not on the taskbar but it is in taskmanager. I went from an NVIDEA card to an AMD card so im new to AMD interfaces. Arma 3 does not work now, it just stops responding, Arma 2 OA doesnt work either, I'll put screenshots of all of the errors i get and the settings on AMD CCC at the end of this. But the problems I get with those 3 games (the only 3 i play on PC) are not the only ones i get, my monitor also "flashes." If anybody has any ideas I'm open to all, I've tried everything I can think of with my knowledge and nothing has worked so far.
Monitor: VX238H
CPU: AMD FX-6300
Motherboard: MSI 970A-G46
GPU: ASUS R9290-DC2OC-4GD5
Screenshots:
http://puu.sh/hqrdM/588f1044f1.png
http://puu.sh/hqDCl/d8c369c14a.png
https://linustechtips.com/topic/354941-problems-with-asus-r9290-dc2oc/
Is it new ?
Did you install without properly uninstalling nvidia drivers ?
Could be a problem with power saving , spend 5 minutes going through bios , try a new install ( or completely remove the old drivers ) ,
If this doesn't work , then return it .
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
Is it new ?
It's brand new, and I wasn't able to uninstall nvidia drivers until this new card was installed because my old card died and i was without a computer for a few weeks
Maybe try a fresh install of windows ( don't delete your current one , just make a new one )
^ this is what I did going from a HD 7770 to a GTX 970.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
