2 Player Problem?
Go to solution Solved by Tim Drake,
Try reinstalling Trials, or updating the drivers of your devices.
I managed to fix it in the game options.
Silly me :P
Okay so I managed to get Trials Evolution working after it wouldn't uninstall so I could play local multiplayer with my girlfriend but the gamepad won't switch to player 2 no matter how many reconnects.
Anybody have any ideas?
https://linustechtips.com/topic/354735-2-player-problem/
SAMWAN PLZ
Don't worry, Samwan is here to help!
On a more serious note, try another local coop game (Broforce, Nidhogg...) and see if that works.
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/354735-2-player-problem/#findComment-4821798
I had tried another game and it seemed to of worked.
I am not sure how I got it to work though.
https://linustechtips.com/topic/354735-2-player-problem/#findComment-4826083
https://linustechtips.com/topic/354735-2-player-problem/#findComment-4826200
Silly me :P
https://linustechtips.com/topic/354735-2-player-problem/#findComment-4826596
