Red LED 120mm, Quiet Fans?
BOTBALL
I need a bit of help on finding some good red LED 120mm, quiet  fans for my build. The color scheme of my build is primarily red which is why I am going with the red LED fans. I only need two of them. If you have any recommendations on what fans I should get, that would be great.
Current Rig: Intel Xeon E3-1231 V3, ASRock H97 Pro4 ATX mobo, 8GB 1600 MHz G.Skill Ripjaws, GTX 970, Corsair 550W, Kingston 120GB SSD & WD Black 1TB HDD, NZXT H440 Case.
Ap121 red ledAre decent
