So i have two gtx 980s but my motherboard and Nvida drivers are only detecting one. device manager is giving me error code 43. i have tried everything swapping pci lanes , re installing driver both cards work fine on there own and i really don't want to re install windows.
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
https://linustechtips.com/topic/353863-sli-problem-please-help/
Have you tried one card in BOTH pcie slots? If either one of them doesn't work it's probably a motherboard issue.
By the way @UpsetPeck please follow your topics yes i moved them to the bottom pci lanes and it still doesnt work
https://linustechtips.com/topic/353863-sli-problem-please-help/#findComment-4809076
I think you meant to write something there?
sudo chmod -R 000 /*
https://linustechtips.com/topic/353863-sli-problem-please-help/#findComment-4809103
i tried that i didnt work
https://linustechtips.com/topic/353863-sli-problem-please-help/#findComment-4809123
he did write
but he wrote inside the quote
look at where your quote ends and his response begins
https://linustechtips.com/topic/353863-sli-problem-please-help/#findComment-4809125
i tried 3 diffrent sli bridges , and yes i uninstalled them first.
https://linustechtips.com/topic/353863-sli-problem-please-help/#findComment-4809133
he did write
OH you're right
Upsetpack it's most likely a motherboard issue. Try resetting CMOS by pulling out the battery for a minute or so, if it doesn't work you should contact Gigabyte for RMA.
https://linustechtips.com/topic/353863-sli-problem-please-help/#findComment-4809154
should i just
OH you're right
i tried that should i just re-install windows maybe?
https://linustechtips.com/topic/353863-sli-problem-please-help/#findComment-4809183
