Pc For Rendering And Editing (Solid Works 3DS Max)
Go to solution Solved by ForsakenLive,
I'd get hyperthreaded E3 Xeons, a rock solid motherboard, get a much more smaller SSD; just enough for the main applications, and of course freeze the systems so nobody puts crap on it, add a hard drive and leave it unfrozen (at least one of the partitions), so people can work without being afraid of loosing their progress if a power surge comes around. A mATX build doesn't look bad, as often space is much more appreciated.
This is a better priced, better performing option.
CPU: Intel Xeon E3-1241 V3 3.5GHz Quad-Core Processor  ($264.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.89 @ OutletPC)
Motherboard: Asus H97M-E Micro ATX LGA1150 Motherboard  ($92.24 @ Amazon)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory  ($94.90 @ Amazon)
Storage: Mushkin Chronos 240GB 2.5" Solid State Drive  ($89.89 @ OutletPC)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  ($69.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($295.00 @ Newegg)
Case: Fractal Design Core 1300 MicroATX Mini Tower Case  ($34.99 @ SuperBiiz)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  ($56.08 @ Newegg)
Total: $1026.93
Generated by PCPartPicker 2015-04-23 16:14 EDT-0400
Inside a professional looking case, all solid parts, stability is pretty much the priority here, but still being able to keep things quiet, with low power usage and high efficiency.
Hi There,
I am currently faced at buying parts or new rigs for the design and technology section of our school.
We are currently running on Hp Desktops for 2008 which have a high frequency of crashing, blue screening and or setting on fire (Cpu Mass Failure)
I think the budget is around 800£-1000£ and they definatley need to be future proof to last at least 5 years.
Currently I had in mind this build
PCPartPicker part list: http://pcpartpicker.com/p/DNZ3kL
Price breakdown by merchant: http://pcpartpicker.com/p/DNZ3kL/by_merchant/
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($218.99 @ NCIX US)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard  ($84.99 @ Amazon)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($108.75 @ Amazon)
Storage: Crucial M500 960GB 2.5" Solid State Drive  ($299.99 @ Mac Mall)
Video Card: PNY Quadro K1200 4GB Video Card  ($369.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($68.99 @ SuperBiiz)
Power Supply: Cooler Master VSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($100.98 @ Newegg)
Total: $1281.57
Im not sure about the graphics card whether i should change it to a Asus Strix 970 or a Gigabyte 970 Windforce.
Im an experienced Builder and just when it comes to a Workstation not a gaming computer im completely useless
What's with the 2 parts lists?
What kind of projects are being worked on and on what scale?
http://pcpartpicker.com/p/pfjkP6
there thats alot better for a school type setting
they will want elegant cases for the school..not gamer type cases
if you can afford a bit more...id change the seagate drive for a wd black one
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
Total: $1026.93
