I'm building myself a Fan less HTPC this is what I got so far
Gigabyte Z97N-WIFI Intel LGA1150 Z97 Mini-ITX Motherboard
Intel Core i5 i5-4690K
16GB (2x8GB) Corsair DDR3 Vengeance Low Profile
Streacom FC8 EVO Fanless Chassis
Samsung SN-406AB  Blu-Ray Combo 8x Slim  3
Streacom 150W NANOPSU
any suggestion for a  Graphics Cards will be much appreciated.
Thank you
https://linustechtips.com/topic/353533-fan-less-graphics-cards/
I bought a gts450 from ebay which had an over sized cooler with no fans. Worked ok for films and stuff but not really enough cooling for games. Most graphics crads will have some way to change the fan curve, maybe just get any card and keep the fans running as slowly as possible.
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804631
It can be done with any 900 series, if you're willing to fiddle around. Theres a guide to it here :) (also i think linus made a video of it)
If not then have a look at asus's Strix line of 900 series cards :) they do it out of the box. (a 960 perhaps?)
Also; there are custom fan profiles in MSI afterburner, but i dont think they can have a 0% fan mode.
Bleigh!  Ever hear of AC series?
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804634
https://pcpartpicker.com/part/asus-video-card-gtx750dcsl2gd5
gtx 750 that id fanless, the highest end gpu i know of with a passive cooler
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804687
Thank you
What is the purpose of your htpc? If its just for video streaming then you overbuilt the CPU and RAM and integrated gpu should work fine. The GPU will be restricted by your case and PSU.
The case you have chosen makes it difficult to install many GPU options because of the limited space that is provided for the expansion card. It needs to be low profile and 1 slot thick. Maybe something like the GT 720 or 730, which isn't much of a performer.
You will also have to consider thermal throttling of the processor. Look at the reviews to see my point. If you wanted a performance fanless HTPC with good gpu support, you chose the wrong case.
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804759
Why is no one noticing that he's using a 150w psu??
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804796
They also missed the case. That PSU can work just fine with a very low end GPU and CPU, but would be tight and your point is a valid given the K processor.
I think there are 750 Ti's with fanless (passive) cooling
Here are lot of options, https://pcpartpicker.com/parts/video-card/#F=1&sort=d8&page=1&qq=1
Any reason for not using onboard graphics?
Sapphire R7 250E Ultimate is the highest-end fanless GPU out-of-the-box.
You could try other fanless coolers which can be mounted on GPUs however that will most likely void the warranty.
Look at his case. I don't think any of those suggestions will work.
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804798
They also missed the case. That PSU can work just fine with a very low end GPU and CPU, but would be tight and is a valid point given the K processor.
a low profile 750ti should just fit, and maybe you can mod the bios to have a 0 rpm fan
but overall the intergrated gpu would do more than fine in most htpc environments
#killedmywife #howtomakebombs #vgamasterrace
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804824
-snip
Whoops, missed that, thanks.
It seems that there is some space for a card.  (up to 230mm long).
However I do think that a low profile 750ti is a good idea, as mentioned (the 960 does seem like a big squeeze and may not have much room to breadth, not to mention power consumption, the 750ti takes 25 watts less). Ontop of that Asus also make a 0db version of the 750ti, which suits Mr.OP :)
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804870
However I do think that a low profile 750ti is a good idea, as mentioned (the 960 does seem like a big squeeze and may not have much room to breadth, not to mention power consumption, the 750ti takes 25 watts less). Ontop of that Asus also make a 0db version of the 750ti.
Problems: Fit. Airflow. PSU
Aren't the 750ti's (with fans) LP all more than one slot thick?
Aren't the 750ti's fanless either not low profile or are also more than one slot thick?
There is little to know airflow in the pcie area. There is not enough ventilation and airflow around the pcie area to cool a 750ti, fan or fanless.
A 750ti and that k processor will be pushing that PSU pretty hard.
Look at that case again. I believe those expansion slots are meant for tuner cards or bottom end gpus.
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804912
you're right, it would be a fun experiment though :)
but in that case (hehe get it :P) just stick with intergrated graphics
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4804942
It seemed to be a double slot space, but again, I think you may be right saying there won't be much space for it.
The biggest problem would be the power I'd assume. And then the thermal throttling. I'd be very curious to see how a card like that would do in such a case.
In that case though I think the iGPU will do the trick. He could do the extra all gpu thing, but that'd somewhat render the point of a htpc moot :P
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4805294
The only fanless 750ti I know is the Palit kalmX and it is like a 3 slot card
Cpu:i5-4690k Gpu:r9 280x with some other things
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4806451
If you are not gaming with this HTPC, just use the integrated graphics since they are not something to laugh about and pick a less expensive cpu. The 4690k is excessive. A i5-4460 or a 4440 would make more sense
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4806461
can you guys also pay attention that its a 150w power supply....the cpu itself is rated at 84w
Phenom II X6 1090T @3.6ghz , EVGA GTX 770 SC, 8GB Hyper-X ram, Adata SX900, WD Black, Corsair HX850, LG IPS234, Logitech G9x, Logitech X-230, Netgear R7000
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4806468
Hence the fitment issue.
butterfish beat you to it by 3+ hours. I also mentioned this. We are waiting to hear back from the OP I believe.
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4806492
the gtx 750 is 20 cm long and the case supports up to 23 cm. why would it not work?
Rigs I've Built
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4809286
1. Its full width card, it can only support low profile.
2. Its likely too thick to fit in the case. It might fit but that would be a strong might.
3. There is no airflow in that area so even if it did fit, it may not have enough airflow to stay cool.
Please actually look at the case. It even says low profile in the specifications.
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4809782
These aren't fanless: they'll still kick in when you load the thing.
Anyone I think this is the best you can get for fanless. (Don't even think it will fit in that case)
http://www.kitguru.net/components/graphic-cards/zardon/sapphire-r7-250-ultimate-review/2/
It's also just about the only thing that will run on that PSU/CPU config.
To be honest, that's an iGPU case.  It's really not meant to house a dGPU.
4K // R5 3600 // RTX2080Ti
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4809812
I agree it is suppose to be a igpu case. Streamcom does make cases that support a dgpu though. The best fanless I believe is actually the 750ti, but both that and your 750 example will not fit. That case only takes low profile cards.
https://linustechtips.com/topic/353533-fan-less-graphics-cards/#findComment-4810568
