Best Case Fans?
Go to solution Solved by MrBucket101,
noctuas
just pick whichever version you need, static pressure, or high airflow
industrial are obviously better, but theres a definite price premium for them
what are you looking for?
airflow? static pressure? silence? looks? price?
there is not one fan that is good at everything
different fans excel at different categories
https://linustechtips.com/topic/353380-best-case-fans/#findComment-4802751
noctuas
https://linustechtips.com/topic/353380-best-case-fans/#findComment-4802756
i think silence, linus said something about them being the best that can do all around while still being quite, i could be wrong though
https://linustechtips.com/topic/353380-best-case-fans/#findComment-4802763
they are quiet but there is quieter
also noctua fans look horrible
the black industrial fans look good but are much louder
the grey redux fans are like their normal fans except grey,so they look better while still being quiet
if you want more quiet, bequiet and fractal design fans give you about the same airflow at 4-5db less noise, but they lack static pressure
noiseblocker eloops have better static pressure but are about as loud as noctua fans
so it really depends where you are putting the fan, what size it needs to be, and what you are using to control the speed (3 or 4 pin)
also what colour you like better, white, grey, or black
https://linustechtips.com/topic/353380-best-case-fans/#findComment-4802797
I happen to like the way Noctua fans look.  There's no mistaking them when you see them!
Case: HAF XBCPU: 4690kCPU Cooler: NH D15Motherboard: Gigabyte Gaming 7 | RAM: Hyper X FuryVideo Card: G1 Gaming 970SSD: 850 EVO |  PSU: Supernova 550 G2 |
https://linustechtips.com/topic/353380-best-case-fans/#findComment-4802860
  • 1 month later...
