So I've heard that the stock fans included with the H440 are loud should I replace them? If so with what as most fans like corsair ones are expensive. I'm only getting 1 corsair fan and thats the AF140 for asthtics. I'm looking for inexpensive silent 120mm fans for the front. I need 3 of them.
https://linustechtips.com/topic/353362-replace-stock-h440-fans/
lol haven't gotten the build yet so I was wondering if there is anyone with an H440 who thinks the fans are loud.
Used to had a NZXT H440. Don't really think the front fans are loud thou. But maybe it's just me. If you wanna change fan, I recommend 2 x 140mm fan instead of 3 x 120mm fan. 2 140mm fan will have same amount of airflow as 3 120mm but would be much much lesser in terms of noise leve.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/353362-replace-stock-h440-fans/#findComment-4802637
