Needing an advice for new wireless mouse!
Hunty
Hello Everyone!
As the title says, i am looking for a new wireless mouse. You need to know, that i have big hands, and i game a lot. (Different kind of games, from FPS to RPG) My budget is around 100 USD, cheaper mouses are welcome too! Every advice is welcome!:)
PS: Yes, i really want a wireless one.:D
CPU: i5 4670k MB: Gigabyte Z97x UD3H  Ram: 4*4 Gb Hyperx Fury  GPU: Asus RoG GTX 1070 Case: Corsair Carbide Spec01 Storage: 2TB HDD/120gb Samsung 840
PSU: EVGA Supernova Nex 750w Display: Benq GL2460HM CPU Cooling: Corsar H105 2*SP120
-snip-
I like my Logitech G602. It has just enough and not too many G-keys.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
Why do you want a wireless one?
The input lag is way too much for gaming
Intel Core i7 9700k - EVGA FTW GTX 970
Really..  <_<
Well, I travel a lot, and i use many PC-s and the cable is allways in the way/ get damaged. Is the imput lagg so noticable? If yes, i consider wired mouses again...
And thanks for many, fast answers:)
Input lag is not noticeable. Maybe on cheap mice that you find in cheap store.
I have used my G602 and some of my friends mice (which are wired) and there was no difference in lag.
EDIT:
G602 is good on battery life as well. I only change mine every 1 and a half months/1 month.
Logitech G602 is the way to go. Long battery life, a good sensor (compared to the shitty ones in other gaming mice), a handful of extra buttons and is not insanely expensive.
Thanks for the advices. Any more toughts on Logitech Performance MX?
Its a good mouse but not made for gaming. The G602 is way better if any kind of gaming is involved.
