I have a 1TB Seagate Barracuda 7200rpm Hard disk drive, and I'm planning to get another 1Tb Hard drive. Will I be needing exactly the same brand and model that I have right now? or will it be fine to get whatever I want?
System:
Intel Core i5 4690k @ 3.5Ghz, MSI z97 PC Mate, Gigabyte GTX 970 G1 gaming, 4x2 Kingston HyperX blu 1600Mhz, 1 Tb Seagate Barracuda 7200rpm, Corsair CX600M PSU, Corsair AF120 Performance edition 3x, Xigmatek Stock fans 3x, Xigmatek Mach PC Case, Asus VX239H 1080p IPS LED 23".
https://linustechtips.com/topic/352228-identical-hard-drive/
Get whatever, unless you want to do a RAID setup, though I wouldn't recommend it if you're still new ;p
Great, thanks! What's a RAID setup?
System:
https://linustechtips.com/topic/352228-identical-hard-drive/#findComment-4788486
Hi there @rmac8530!
If you're going to use it as a second separate storage location, then you can go with pretty much every HDD you want.
However, for RAID it's not recommended to use different drives because it tends to lead to performance problems. For instance, the volume can only be the size of the smallest drive (or a multiple of it depending on raid level), and also different speed drives cause sync issues which means more latency.
Hope this helps.
Cheers! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
https://linustechtips.com/topic/352228-identical-hard-drive/#findComment-4788597
