http://au.pcpartpicker.com/p/Pzn9Q7
Was just curious to see what you make of this build I'm planning :)
(These are just my personal opinions btw). Might want to change the video card. You can get a cheaper better performing GTX 970 with less power and heat output. Or, if you're going to spend $700 on a graphics card, go with a GTX 980.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/350299-thoughts-on-my-build/#findComment-4765475
Read this and edit your post later.
http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
We can't recommend anything ,because we have no idea what you will be doing.
https://linustechtips.com/topic/350299-thoughts-on-my-build/#findComment-4765477
However seeing that the 980 starts at around 750... damn.
Still you could get two windforce 290's for 800.
There are 980s out there that are only $500
https://linustechtips.com/topic/350299-thoughts-on-my-build/#findComment-4765493
Besides being able to get the OS for 1/15th the price on G2A or reddit/r/microsoftsoftwareswap it looks great it me!
Like the option of going for a 290X 8gb over some other 980s, the more vram can be useful in gaming on multiple 1080p monitors, and the performance difference between the two isnt the biggest gap.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/350299-thoughts-on-my-build/#findComment-4765501
That PSU is really expensive, it's a quality PSU made by Seasonic but it's far too expensive for 760W
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/350299-thoughts-on-my-build/#findComment-4765553
