I have built a new pc and when I use it normally it works fine but when i try to record or live stream a game mainly minecraft it lags a lot and droppes down to 14 fps from 50. I record in obs and have tried changing the settings but i cant get it to work.
Please Help
My build:
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor
Motherboard: MSI A78M-E35 Micro ATX FM2+ Motherboard
Memory: Kingston Fury Series 8GB (1 x 8GB) DDR3-1866 Memory
Storage: Corsair Force LS 60GB 2.5" Solid State Drive
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Asus Radeon R9 270 2GB DirectCU II Video Card
Case: Zalman Z9 Plus ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)
Wireless Network Adapter: TP-Link TL-WN851ND 802.11b/g/n PCI Wi-Fi Adapter
https://linustechtips.com/topic/349282-help/
Streaming is CPU heavy, relatively speaking. I don't think the athlon can stream too well. Also, your internet upload speeds need to be decent for streaming to prevent lag (not fps dips, that's probably the cpu issue). You can try to stream at lower birates and lower quality to see if it works.
https://linustechtips.com/topic/349282-help/#findComment-4753026
hows the CPU and GPU usage looking?
Seems like a bottleneck
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/349282-help/#findComment-4753034
I dont really stream i record really
https://linustechtips.com/topic/349282-help/#findComment-4753039
