@AlwaysFSX is the guy fro OBS information so I;m tagging him.
But I would suggest using quicksync or use shadowplay instead.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
ENCODING:
x264 encoder, CBR enabled, max bitrate 3500, AAC audio codec with 160 bitrate
VIDEO:
Resolution downscale: 1080p + 30 FPS
or 720p + 60 FPS
ADVANCED:
Default for safety, but you can try x264 CPU Preset "Faster".
Is you upload actually 5M (as in 5M at speedtest.net) or is that the advertised speed? If you don't actually get that 5M you might want to lower the max bitrate to 2500 and audio bitrate to 96.
