whats your budget? there are better coolers than those
https://linustechtips.com/topic/348585-cpu-cooling/#findComment-4744461
budget is not a case...I need very easy instalation that do not require backplate mounting....and these also have termal paste on them already  :unsure:
What are you cooling?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/348585-cpu-cooling/#findComment-4745653
Something that hard with backplates? Those are more safe than coolers without them. If you getting cooler without backplate, you will need to know max weight mobo can handle. Otherwise it might bend because of cooler. As for which is better, Extreme. It has bigger fan and more surface area.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/348585-cpu-cooling/#findComment-4753905
I was worried about changing my gpu  :D I am big tech noob but thanks to linus I started improving my PC  :lol: so I am scared that I would screw something when removing my motherboard  :huh:
https://linustechtips.com/topic/348585-cpu-cooling/#findComment-4753933
