Hello I am thinking of building a pc for the second time round now as mine is getting outdated and i want a new one as upgrading is pointless I have a budget of £800-900  I was thinking of getting a mini itx pc the specs are
Intel Core i7 4770
Gigabyte H87N-Wifi
8GB Corsair 1600mhz Vengeance
500GB S-ATAIII 6.0Gb/s plus my own 1tb drive with windows 7 64bit ultimate
NVIDIA GeForce GTX 770 2GB
650W Corsair VS
Fractal Design Node 304 - using a stock cooler soon to buy a sff noctua cooler
feel free to write any suggestions or list some recomended parts
Owner Of The Crappy .gifs
https://linustechtips.com/topic/34834-new-build-help/
Good choice of parts for a H87 Mini ITX build in my opinion, no need for a K model.
Edit: Or just change the i7 for a i5-4670k, it's cheaper and is almost as powerfull as the i7.
VIDEO GAMES                                  Max Power Build Log
https://linustechtips.com/topic/34834-new-build-help/#findComment-445940
Add in an ssd.
The psu is overkill. A good 500-600w will do.
https://linustechtips.com/topic/34834-new-build-help/#findComment-447313
