you cant
lol
this is why you replace hard drives BEFORE they fail :)
https://linustechtips.com/topic/348305-hard-drive-died/#findComment-4741091
What drive is it? Do you know what failed? If it's external there's a good chance that there's also a USB connection as well as the firewire. Even so, opening up the case will give you a plain sata drive. Try it bare in a system. If the drive is gone, there are tools that can get you a recovery.
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/348305-hard-drive-died/#findComment-4741116
I have no idea how to get things off of a hard drive once its crashed. Next time try 2 hard drives and run it in RAID 1 (mirror). so if one fails you still have the other.
Case: NZXT S340 || CPU: i7 4790k || Cooler: Hyper 212 EVO || GPU: GTX 770 || Mobo: Z97 PC Mate || Storage: 240GB Sandisk Extreme Pro || RAM: 4x4GB 1333mHz
https://linustechtips.com/topic/348305-hard-drive-died/#findComment-4741126
are you abel to tear apart the drive to the plain SATA drive?
you can then try installing the drive into the PC and see if the drive is detected
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/348305-hard-drive-died/#findComment-4741415
