Yes for every 0.1  increase u need to increase the voltage a bit maybe 5%
CPU AMD 9590 -- 2x Titan X ---  RAM 32GB KINGSTON---PSU EVGA 1000 ------ HARD DRIVE 2TB WD BLACK -- MOTHERBOARD AMD 900 SERIE
RAZER CRACKEN ---------RAZER NAGA -------------------RAZER CHROMA
english is new language for me so forgive my many mistake / I have moderate autism so im not always correct
Ultimately, it depends on the chip. Most likely you won't need to.
5% for every 0.1GHz? That's a lot.
Increase slowly, when your system becomes unstable then increase the voltage but watch the temperature.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
I have an i5 2500k CPU at base clock and am thinking about overclocking it. So say if I just wanted to overclock it from 3.3 to say around 3.7 would I still need to change the voltage settings? I'm not trying to get as much as I can out of it just a tad bit more.
Look up some guides online and familiarize yourself with the terminology and take it slow.  overclocking is a process.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
You'll never know until you try it, every chip is different. No reason to be afraid of bumping the voltage up slightly, unless you're running it on the stock cooler...even then might be able to handle a smidge.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
It really depends on your chip, if you are lucky enough to increase your clock speed and remain at the same voltage at a stable performance then you are lucky enough :D
But for most cases, increase your voltage a bit and run a stress test, see if you can get a stable chip
It's funny how everyone said it depends on the luck of the chip  :P
Well its a mixture of multiple things, sometimes it is the luck of the chip. Then VRM's and Power Phases.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
The turbo frequency is for one core. It doesn't mean it'll work on all four.
