I have never seen that but that would be amazing!
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/346097-ps2-case-for-pc/#findComment-4713136
Has anyone ever seen a ps2 case being used for a PC? I was thinking about using a laptop motherboard ? Anyone got any ideas all help will be greatly appreciated :)
Have a try.
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/346097-ps2-case-for-pc/#findComment-4713157
I don't think its possible because not even Mini ITX fits inside a PS2 Case. Sorry :P
The original PS2 was 12" x 7" x 3" externally. Mini ITX motherboards are 6.7" x 6.7". If you can carve out a space inside for it to fit, it can fit. Probably not though, I'd bet it has thick walls.
https://linustechtips.com/topic/346097-ps2-case-for-pc/#findComment-4713168
@Jack.EXE
https://linustechtips.com/topic/346097-ps2-case-for-pc/#findComment-4713198
I know he did a build log on it, but was too lazy to search it up ;)
https://linustechtips.com/topic/346097-ps2-case-for-pc/#findComment-4713234
I could get a mini itx mobo and mount it to the top of the case I will use a laptop size HDD (sorry forgot size so didn't put size) dont know about fans and my main concern is fitting a PSU in that case .. Is there any way to use a laptop power brick or similar?
https://linustechtips.com/topic/346097-ps2-case-for-pc/#findComment-4713374
its all good i have found one on amazon but i am a bit confused as i am a noob when it comes to m-itx and small form factor stuff . so you need the power supply (that pico one) and then a power brick (like a laptop one) ? sorry for all the questions i really dont know what i am doing when it comes to small form factor builds  <_<
https://linustechtips.com/topic/346097-ps2-case-for-pc/#findComment-4727842
right basically the ps2 is way to small for all of the components i want , but i still really want to build this pc so does anyone have any ideas as to what i could use for a case? i have thought about an old standalone cd player? or a bigger console? really want your input (anyone reading this)  :D
https://linustechtips.com/topic/346097-ps2-case-for-pc/#findComment-4728049
