Radiator help
Solved by W-L,
Thanks guys, I am going to use it as a stacked system with 1 915r at the bottom the atx case in the middle and two 915r's on top with 2 radiators in each
here is a link to everything that will be in the system
https://docs.google.com/spreadsheets/d/1UTSF4HGtfg_7zibyOUbv18voVGULwwvRfTinwX44QkY/edit?usp=sharing
Yep that looks pretty good and you'll be fine if you just using the 915 as radiator boxes.
