Need help please.
Go to solution Solved by Redsun20,
Yes. 802.11n is the standard of wireless your router uses. I would recommend a TP-Link wireless card, like this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16833704129
It is inexpensive, reliable, and are not taking up usb ports just begging to be snapped off.
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/345595-need-help-please/#findComment-4706703
Buy a USB WiFi dongle that supports N.
https://linustechtips.com/topic/345595-need-help-please/#findComment-4706704
9590|EK-Copper|Sabertooth 990FXR2.0|16GB RIPJAWS Z|Dual MSI Gaming 290|Corsiar AX1200i|Corsair 760T|3TB Seagate+Dual 120GB Samsung 850EVO in Raid 0
LTT'S Official Radeon Master Race Club Founder-Predicts TitanX2 (Prediction Date: 3-30-15)
XFX Needs To Make A 3 Fan Cooler
https://linustechtips.com/topic/345595-need-help-please/#findComment-4706706
Are you close enough for a cable? You can get a 100Ft cable for $10 and that will work worlds better than wireless.
Otherwise, a TP-Link usb dongle is fine.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/345595-need-help-please/#findComment-4706713
Learn from Qain.  Use a cable.  You'll thank yourself later.
This video shows you how to build your own but you can buy them.
But if Wifi is what you just must have then any pci-e tp-link n adapter will work.  They are cheap and easy to install.  Usb has overhead issues and is buggy in my opinion.  But just to be clear.  Cables are king.
Laws only govern the honest.
https://linustechtips.com/topic/345595-need-help-please/#findComment-4715218
