literally nothing
wait until at least your cpu / ram / storage gets there
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/344990-build-help/#findComment-4699048
I can't wire anything and I do have storage and a gpu
no cpu no build
itd be like a human without a brain
https://linustechtips.com/topic/344990-build-help/#findComment-4699067
Nothing really. Ideally, you want to mount your CPU to the mobo first, then the cooler and ram. Then install the mobo and cooler into the case and connect the fan and usb headers. Then your install optical and storage drives and run the connecting wires. Then the GPU(s) and finally install the PSU and runn the power cables.
CPU: Intel Core i7 4790k @ 4.6ghz, Cooling: NZXT Kraken x61(Push/Pull), MOBO: EVGA Z97 FTW, OS: Windows 10, RAM: 16gb EVGA SuperSC DDR3 2400, Storage: Samsung 850 Evo 250gb + 500gb SSD, WD Black 1tb HDD, PSU: EVGA SuperNOVA 1000w G1, Case: NZXT Phantom 530, GPU: 2x EVGA GTX 980 CLASSIFIED, Monitor: Seiki 39 inch, 1080p @ 120hz, 4k @ 30hz
https://linustechtips.com/topic/344990-build-help/#findComment-4699081
I just got my case,psu, and motherboard what can I set up
With just those cause my other parts are going to take a while to show up. I already have them in the case
You can plan your wiring route, check for clearance on your parts, and... idk, guess that's about it.
get your twisty ties set in good spots, get your case fan's wiring nice and clean.
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/344990-build-help/#findComment-4699148
installing the CPU and cooler when the mobo is in the case can be tricky
installing RAM with the tower cooler installed is even harder!
trust me
it a pain to get things installed when everything is inside the case and you got like big hands
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/344990-build-help/#findComment-4699236
