I've just setup my new rig with a Corsair H100 and 2 fans on it. The pump is running and the fans are moving, but the problem I have is that the button on the CPU block and surrounding area are not illuminated like I've seen online. Any ideas on what might be the cause of the problem are much appreciated.
https://linustechtips.com/topic/344857-h100-problem/
@Enderman might be able to help
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/344857-h100-problem/#findComment-4698274
pushing the button does not make the LEDs turn on?
then its probably just that the led controller died
https://linustechtips.com/topic/344857-h100-problem/#findComment-4698454
If the button does not make it turn on, and corsair link doesn't make it turn on, RMA it.
Corsair has an amazing RMA process.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/344857-h100-problem/#findComment-4699889
Sorry only got on now, thanks for the replies and suggestions. The lights are all that's not working on the unit so if there is nothing that I'm doing wrong or I'm missing something then I'll just deal with it I guess :(
Do you have the USB plugged in to the motherboard?
https://linustechtips.com/topic/344857-h100-problem/#findComment-4702894
