Need Help Deciding!
Solved by Guest,
Ok so this is what i came up with. You have psu, gpu, ram and hdd. 4 parts subracted. Any case at 29 pounds is good. Core i5 4670k for cpu is the best for gaming and vector work so go with it at arround 190 pounds. For mobo any z87 from MSI at 95 pounds is good. I recommend g43 atx. And hyper 212 plus for cooler is good. And any dvd drive is also, and you actually dont need it. It goes on 350 pounds. Is that good for you?
