I barely understand it so can someone give me the answers and show me how to do them for this and please don't just say "do your own work"
1.  Write the product as a trinomial.
 (x + 2)(x + 4)
A.x2 + 8x + 8
B.x2 + 8x + 6
C.x2+ 6
D.x2 + 6x + 8
2.  Write the product as a trinomial.
 (m – 6)(m + 3)
A.m2 – 18
B.m2 – 3m – 18
C.m2 – 3m + 18
D.m2+ 3m – 18
3.  Write the product as a trinomial.
 (2x + 3)(4x – 2)
A.8x2+ 8x – 6
B.6x2 + 13x – 6
C.6x2 – 5x – 6
D.6x2 – 13x – 6
4.  Write the product as a trinomial.
 (3r – 4)(r + 8)
A.3r2 – 32
B.3r2 – 28r – 32
C.3r2+ 20r – 32
D.4r2 + 4r – 32
5.  Write the product as a trinomial.
 (k – 2)(k – 1)
A.k2– 2
B.k2 + 3k + 2
C.k2 – 3k + 2
D.k2 – 3k – 2
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/343348-help-with-polynomials/
FOIL (First, Outside, Inner, Last). Remember that.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677153
OK but that doesn't really help me
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677176
I'm not going to solve this but here's websites that'll help (they got me though alot of homework)
mathway.com
wolffarmahlpa.com
also just google ''polynomials calculators''
The time you enjoy wasting, is not wasted time.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677180
FOIL is a good method, however I like to think of it as distributing twice. you take the first element and distribute it to the second polynomial. Then you take the second element and distribute it to the second polynomial.
For example:
(x+2)(x+4)
(x)(x+4)  and 2(x+4)
Just be sure that you don't lose negatives
Does not having a second parenthesis around something bother anyone else as much as it does me? (Like if this statement was missing a second side)
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677192
Polynomial calculator. Used it all the way through my last college algebra class.
http://www.webmath.com/polymult.html
May I never have to take math again.
mathway.com
wolffarmahlpa.com
That's exactly what I did.
Dubs are better than subs
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677195
So, first problem. (x + 2)(x + 4).
Applying the FOIL method.
1. F for First. You multiply the first variable in the sequence, x and x, so multiplying that gets you x2
2. O for Outer. You multiply the outer variables, in this case 4 and x, getting you 4x
3. I for Inner. You multiply the inner variables, 2 and x to get 4x
4. L for Last. You multiply the constants in the end, 2 and 4 to get 8.
Now add them all up. It's supposed to come out x2+4x+4x+8, or simplifying like terms x+8x+8.
Repeat process with other problems.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677216
If you just copy+paste answers you are setting yourself up for failure.
Here is a good website you can search with to learn different subjects. khanacedemy.org There are videos and practice questions to help you.
The basics of this is FOIL.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677306
Here is a good website you can search with to learn different subjects. There are videos and practice questions to help you.
it was an online test all I had to do was select a box
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677380
That's simply an excuse to cheat, and is setting you up for failure (not to mention simply cheating yourself).
Actually learning the material is 100 times better than cheating.
YouTube some videos on the FOIL method. Maybe check out patrickJMT. He does a lot of math related videos, and shows you how to do it pretty easily.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677424
here is an example
(x+1)(x-3)
step 1. do FOIL
x*x    x*-3    1*x   1*-3
x^2   -3x      +x      -3
step 2. combine like terms
x^2  (-3x + x) -3
step 3 simplify
so(x+1)(x-3)= x^2-2x-3
hope this example helps
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677428
I went through the lessons many times and just didn't understand it
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677448
Are you still having trouble with the foil method? No friends/relatives that know it could help you?
i got it done thanks to the website trik'stari linked and nope non of my relatives know how to do it
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677518
But you need to at least know how it's done in case you don't have a calculator like that.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677523
it shows how to do the equation
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677529
If for some reason you don't get this method : (x+2)(x+4) = x * (x+4) + 2 * (x+4) = bla bla bla , then let me explain it to you.
You have (x+2)(x+4).
We don't know what that does, but we do know that :
z*(x+y) = z*x + z*y. (whatever the x , y and z)
Back to our original equation (x+2)(x+4)
Let's have a = x + 2.
a(x+4) = a * x + a * 4 = (x + 2) * x + (x + 2) * 4 = x^2 + 2x + 4x + 8 = x^2 + 6x + 8.
Generally :
(a + b )*(c + d) = ac + ad + bc + bd (whatever the a , b , c and d)
That's if you really needed the explaination, even though it's simple enough without it.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677592
Seriously?
That's what you do in college?
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677669
Seriously?
For an algebra class? Yeah pretty much. It's online lol
Apparently people aren't aware of smartphones.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677778
Well, your site can't do this :
(x^2 + 4 + x^3 - 9)(x^2 + 4 - x^3 + 9)
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4677819
FOIL in my opinion is fairly retarded. Here is a visual look at what is happening:
b9b85cb1ce1e2381599b65b6d03c6add_zps1434
This is known as the Area model/method (or less commonly known as the "box method"). Take each binomial and split it up on the sides of a box. Draw lattice in the box separating your terms. Then find the product in each square by multiplying the number at top and to the side of the box. Finally take the products inside the box and add them all together and simplify/combine like terms.
I teach this to students in college algebra (as I am a tutor), and this is by far the best way to show what is visually happening. There is also a neat video explaining this here:
EDIT: I use this method when I have to manually multiply polynomials of order 4 or greater together. It helps you keep track of all the terms  :D .
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/343348-help-with-polynomials/#findComment-4678089
