hey guys im building a new pc i need a good case with great airflow wel amazing asw im housing 2 980s in it,and the summer tends to get hot soo ive looked at a few,like the Haf x,the phantom 820 thermaltake level 10gt and the 780t but cant choose soo id like some help or maybe some othercase that u guys might recommend thanks
https://linustechtips.com/topic/342083-need-a-case/
Phanteks Enthoo Pro/Luxe
Corsair Air 540
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/342083-need-a-case/#findComment-4660453
I've done plenty of research on the phantom 820, I think very highly of it's airflow. it has 200mm front fan, a mounting position for up to a 280mm bottom rad (2x140) and up to a 360mm top rad (3x120mm) if watercooling's your thing. If not you can just place fans there (you could place a 200mm fan on top for quieter cooling), there's also a mounting spot for a 120-140mm fan on the hard drive bay (a great feature, you could point it at your graphics cards) and you could mount a 200mm fan on the side if you want (not too aesthetically pleasing). If it tends to get hot I'd recommend you get it in white. I think it's phenomenal.
https://linustechtips.com/topic/342083-need-a-case/#findComment-4661858
Great airflow eh?
Corsair Air 540
Fractal Design Define R5
I have the Corsair 780T and highly recommend it. Has great watercooling support. I fit 2 360mm radiator (60mm thick)
Case Phanteks Enthoo Evolv ITX | Motherboard Asus ROG Strix Z270i | CPU Intel i7-7700K | RAM Team Vulcan 16GB DDR4 | GPU Geforce GTX 1080 Ti | Storage Crucial MX300 1TB M.2 | PSU Corsair RM750x
https://linustechtips.com/topic/342083-need-a-case/#findComment-4661944
wel im only gona cool my cpu with those sealed loops,and i took a look at the storm series its nice but cooling doesnt look to awesome for me,basicly im aircoolig my GPU thats my main concern looks or something doesnt matter just need my GPU to stay belowe 80C and i wont be overcloking them
https://linustechtips.com/topic/342083-need-a-case/#findComment-4667512
I have the Air 540 and it's amazing, great cable management so it won't sacrifice looks and the
PSU is in a different compartment than the rest of the components. As the name says, it's made for great
airflow and is more than likely to support your x2 980s as it can support 4  :D
CPU: Intel i7-4790K @ 4.7GHz --- RAM: Lenovo 1600MHz 16GB --- MOBO: Gigabyte Z97-G7 --- GPU: EVGA GTX 970 FTW ACX 2.0+--- PSU: Corsair CX600 --- Case: Corsair Air 540 --- Cooler: NZXT Kraken X61 --- OS: Windows 8.1 --- Monitor: 24" AOC G2460P + Dell 19" --- Mouse: Logitech MX Perfromance --- Keyboard: Corsair K70 (Cherry MX Brown) --- Audio: Sennheiser HD558
Don't buy a GTX 980, it's overpriced! Buy 2 GTX 970s or 2 R9 290s intstead (the R9 290s would even be cheaper)
https://linustechtips.com/topic/342083-need-a-case/#findComment-4670413
